D dougie64 New member Joined Jan 29, 2010 Messages 16 Points 7 Apr 27, 2010 #1 hi all,does anyone no or have any idea why the fan on my siecento 1108 abarth sporting keeps cutting in and out,cuts in when it gets hot but cuts out 10 secs after,and so on,,any ideas .
OP OP D dougie64 New member Joined Jan 29, 2010 Messages 16 Points 7 Apr 30, 2010 #2 come on someone must no this one.
Most Easterly Pandas Speed Reader of the Year! Parked in the garage Written a guide Joined Aug 15, 2007 Messages 44,236 Points 7,382 Location Norwich, Norfolk Apr 30, 2010 #3 Dodgy fan switch?
OP OP D dougie64 New member Joined Jan 29, 2010 Messages 16 Points 7 May 1, 2010 #4 what as in sender unit or something else,
Y ycming Patron member Written a guide Joined Oct 13, 2006 Messages 10,264 Points 1,600 Location Glasgow May 1, 2010 #5 Is normal, when the temp is below 90 the fan will stop. And repeat once it rises above 90. Ming
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,862 Location Lake District....Moist May 1, 2010 #6 Unless the fan motor is drawing too much power due to the bearings beginning to seize. Check the draw. Cheers SPD
OP OP D dougie64 New member Joined Jan 29, 2010 Messages 16 Points 7 May 2, 2010 #7 rallycinq said: Unless the fan motor is drawing too much power due to the bearings beginning to seize. Check the draw. Cheers SPD Click to expand... ta mate will have a look at that
