Technical Punto 75 Throttle Body
DJ_Bucho
Established member
Co. Durham
Ok having seen the post a little while ago (See link below)
https://www.fiatforum.com/showthread.php?t=8481&highlight=38mm
I've decided to bite the bullet as it were and purchase myself a Punto 75 Throttle body.
Now as many people on here will tell you it isn't a direct swop for my Cinq.
For a start the Punto 75 is a MPI engine, so the top part of the throttle body doesn't have the injector or anything on it, so the top part of either a Cinq, Sei or Punto 55/60 throttle body is required.
Lucky thanks to a very good mate (Thanks Brickfoot :D) I managed to get hold of an old Cinq 1108 TB. (See "Top Half of 1108 TB.jpg" below:)
I got my Punto 75 throttle body from Ebay and it was delivery to me on Saturday, I took some picture as soon as it arrived and these are shown below.
Thanks to Pete Gas Flowing guide (Thanks Mate :)) I'm in the process of flowing top half of the 1108 TB, the bottom half of the Punto 75 TB. The shaft is also going to get a good flowing (uh ur misses), as well as the butterfly. I'm going to get my dad's friend to turn down the alloy spacer block so it isn't quite as tall, as well as flow the spare inlet manifold I have and bore out the inlet hole so that it matches the Punto 75 Alloy spacer block.
I know its going to be quite a bit work to get all of this done, but I think it will definatley be worth it, and I should definitley gain a couple of extra bhp ready for York ;)
I'll keep this thread updated with the progress of my work.
Wish me luck, I hope I can get it all sorted.
Well as I do each part of the conversion,
I'll promise I'll take pictures and keep the forum updated with my progress.
It will be like a guide, but will only be updated as and when I get parts finished.
I'll be working on it tomorrow, and Friday, but I'm working nights on Friday, Saturday and Sunday, but I'm hoping I can get my dad's friend to do the laith work on Monday or Tuesday night.
I'll keep you posted.
Brian
Out of interest, who off of ebay did you buy the TB from?, might be good to know when i start looking for a TB myself,
cheers,
Nath
The throttle Body inself wasn't advertised for sale on ebay.
I'd been looking for one of these throttle bodies for quite sometime now, and I saw a fella advertising he has breaking a Punto 75 ELX, so I messaged him asking if I could buy the throttle Body from him.
He replied saying he'd be happy to sell me the throttle body, so thats how I got it.
The fella I bought it from is called "Dave", but he appears to have removed the Punto he was breaking from Ebay.
His email address is [email protected]
If anyone wants to conntact him about any other Punto 75 ELX part they may want.
Hope that answers your questions.
Brian
I must admit "Tricker..." your throttle bodies do look good, but I can't really justify spending that much.
Plus I'm gas flowing my Punto 75 throttle body so the difference in flow rate between that and the 40mm throttle body won't that that great.
Well I've heard good reports on the 32mm Punto 60 throttle Body, But I really wanted that little bit extra, So I decided on the Punto 75 38mm throttle body.
I know its going to take quite a bit of work, but I think it will be worth it. Plus what I am doing will be unique and no-one else will have a throttle body the same, as I am getting my dad's friend to modify the TB and the alloy spacer block, plus the inlet hole on the inlet manifold, so it should be really good.
Thanks for the info, thought it might have been from a breakers, good luck with your TB, look forward to seeing it develop,
Nath
Thanks very much for the encuragement, hopefully I'll have some more pics to post up tomorrow for everyone to see.
Ok here's today's update.
Having fully stripped the Punto 75 throttle body I've cleaned every single part in the parts washer, so their all nice and shiney :D
The first three pictures show the main parts of the throttle body, (the top part of the throttle body won't be used, but I thought I'd include it anyway).
I've gas flowed the shaft of the throttle body and I must admit although it took me the best part of 3 hours :(, I'm REALLY pleased with the end result.
I started shaping the shaft with a small file to get the rough profile I wanted, then I used a sponge sanding block to get rid of any of the scratch's the file had left.
After the sponge sanding block I used some 300 grade wet and dry, and then moved onto some 600 grade and finally 1200 grade. After I had done that I got out the Dremel and used one of the polishing pads with some rubbing compound to finish off the shaft and give it a supper smooth finish.
I then moved onto the butterfly. Putting the shaft back into the throttle body and re-inserting the butterfly I could see exactly which parts of the butterfly made the seal. I then marked the reverse sides of the butterfly that didn't make the seal so that I knew exactly which parts of the butterfly I could smooth.
Although the pictures are great (Ok there pretty bad I know), you can just about see the smooth edge of the butterfly. If you don't really know what I mean, the edge profile of the butterfly was very similar to that of a 2p piece.
But it now is smoothed into a thin knife edge to help aid in the flow then the throttle is open :)
Let me know what you think, and I'll keep you updated with further progress reports.
Brian
Well the maching has been done,
Me and my dad popped over to one of his friends last night and spent a good couple of hours maching the throttle body and the spacer.
I know just need to give them a little rub over with some wet and dry, get my spare Inlet manifold all cleaned up, and then paint it as well as the throttle body and then I can start to re-assemble it.
I've not got any photo's of the machinging yet, but as soon as I do I'll get them posted up for everyone.
Brian
Well I've only got a standard 30mm Cinq throttle Body on at the moment so I'm hoping that the gains will be pretty noticeable.
I've done a spreadsheet calculating the total area that the air can flow through when the throttle body's butterfly is fully open.
I entered the figures for my gas flowed 38mm Punto 75 throttle body and the difference between this and the 40mm throttle Body "Tricker..." has made and was advertising is only 4%, so I figure what with my flowed inlet manifold that I'm in the process of completing, I should be looking at a power increase close to what "Tricker..." has stated for his 40mm throttle body, which is:
"Best results from a Cinq. 1.1 96' before and after a 40mm TB
Before: 61.6 hp and 84 Nm at 6214 rpm.
After: 67.8 hp and 92 Nm at 6214 rpm.
The engine in running standard with only K&N induktion kit"
So acording to "Tricker..." his 40mm throttle body gives his car a 6.2bhp increase in power, so hopefully I should be looking at about a 6bhp increase.
I won't know exact power increases as Mr Cinq hasn't been on a rolling road before, so this is purely an estimate, but I'll let you know how it feels when I get it fitted.
Oh and the complete throttle body and spacer cost me £45 delivered, the machining was done by my dad's mate (so only cost me the price of a 4pack of Caffrey's).
The gas flowing of the inlet manifold, the throttle body shaft and butterfly, and the flowing of the top half of the throttle body was done all by myself so only cost me my time. So all in all the throttle body's cost me about £50 which I don't think is bad at all, although it does require A LOT more work than "Tricker..."s 40mm throttle body.
Pictures will follow shortly.
Brian
Is it on yet Brian?
This is beginning to get interesting...Im thinking I might well see what I can do with a machine shop and a 32mm TB...;)
No mate its not on yet, I've just got a little bit of tidy'in up to do.
Plus I wanna spray the inlet manifold and throttle body black so it all looks nice :)
Don't worry you lot will know as soon as it's fitted trust me. Pictures should be up tomorrow sometime :D
Brian
I sound like a broken record when commenting on this guys car but once again he takes time and care and ends up with some of the best mods you have ever seen this side of Centoland!
Should perform and look ace Brian.
Liam
