It's not got a rear axle, there is a rear beam and two rear trailing arms. It has fully independent suspension.
Ask what exactly is failed, is it the beam maybe from rust, or is it the more common bushes on the arms, if so these can be replaced with new bushes eithe rpoly from PowerFlex (though factory burned down recently so stocks low) or rubber aftermarket OEM spec on ebay.
To answer your question, yes they are the same.
