the gardener
- Feb 1, 2010
- 35
- 10
Hi Again, Have any of you replaced your rear engine/gearbox mount on a cinquento?
If so any how to,s or tips?
Cheers!
Smon
Cheers!
Smon
mine needs doing too, hopefully some one might be able to help
Thanks All!
Took me 45 mins to remove the bush and i now await delivery of new bush for fitting. Much easier job to remove than i thought.
Only problem was that on two of the bolts there is very little clearance so you have to use a spanner and not a socket.
Only two bolts?
Iv'e removed four bolts but obviously two didn't need to be removed.
This usually happens when i do diy on motors but at least i know where they all go.
Have'nt put it back together yet as still waiting for part.
Only two bolts?
