Technical Technical: Engine management warning light and rough running
badawn
L reg Cinq seems to run fine but only seems to be running on 2 of the 4 cylinders.
Red Spark plug light on constantly.
wont do above 55 mph
would it be worth geting a new set of coils ?
plugs and leads are going to be changed too along with oil and filters
any ideas thoughts or just plain help would be fine
i have never come across this problem before rest of the car seems to be running and doing what it should
awaiting your replies
thanks in advance
Ads
Re: Engine management warning light and rough running
thanks in advance
Ads
This would be bnetter asked in the cento section, but, while we're here, with engine running remove and replace one plug lead at a time to find which coil is causing trouble.
SPD
cheers for that do you think it could be the ecu by any chance i will take leads off tonight and see which coil is giving me trouble ?
thanks
ads
ok new coils fitted and seems to be firing on all four cyclinders now but wont rev fully seems to struggle at high revs like its being starved of something ??
red spark plug light still on too would disconnecting the battery for 24 hours clear this fault ?
cheers
ads
Did you do as rallycinq suggested or just change the coils? Have you changed the leads and plugs? It's important to diagnose a fault before throwing money at it (unless you are very rich).
Disconnecting the battery -ive for 10 minutes or so will clear the fault, but the chances are -- if it's running rough -- that it'll come back.
i have as yet just changed the coils.
the plugs i will change today when i pop to the motor factors
the leads seem to be ok no arking as i can see seems to run fine until you hit the acceleratror then it will rev up fine then gets to a point where it seems to be struggling to get any higher ?
i personally dont think its the leads but i am no expert
thanks for all the help so far
Ads
Ads
Reduced ability to rev, car is in limp home mode.
There is a sensor playing up, I'd probably start with the O2. don't change it, check it.
Could be TPS, so, again check before replacement.
Nominlas are in the FAQs I think.
SPD
can any one tell me the firing order on the coils as i think they mabee wrong
starting at the top of coil 1 and working down to coil 2
i have the order of
(3) top
(2) coil
(4) bottom
(1) coil
I think someone has fitted the leads incorrectly before i had the car ?
thanks
Ads
:devil:
All sorted seems like it was one coil and a HT lead was Damaged along with the spark plugs on 2 and 4 burnt out totally so all replaced new leads plugs and coils.
after scraping away the crap and build up of muck i found the Ht order as said on the back plate
No more lights no more revs right through the range with out holding back now.
so touch wood all sorted
Thanks for all the advice
much appreciated
Ads
:devil::devil:(y)(y)(y)(y)(y)(y)
