FIAT Auto Specialist Team
Thread Tools
Old 30-09-2004   #1
Trader Rating: 1
NowIsGone1106 has donated!
Post Emmisions MOT Fail
was wondering if anyone could help
my sei failed its MOT as it failed the emmisions test. the lambda sensor was at fault.. a mechanic mate fitted a new one for me today.. when it got re-tested the lambda sensor emissions was within the tolerance boundaries but still high??
has anyone experienced this? has the ecu gotta 'learn' as the sensor is new? someone sugested disconecting the battery to re-set the ecu?! but F**k that! lol.. it has passed.. so im not that fussed...
but any ideas?
thanks in adavnce
alfie
NowIsGone1106 is offline Reply With Quote Quote
Old 30-09-2004   #2
BabyPunto Owner
Babysei's Avatar
Babysei has donated!
Re: Emmisions MOT Fail
mmmmmm not sure but u r one fiiiiiiiiiiiiiiiiiiiiiine man
Babysei is offline Reply With Quote Quote
Old 30-09-2004   #3
Super LOL!
Stu DemonD's Avatar
Trader Rating: 1
Stu DemonD will never be forgotten
Stu DemonD has donated!
Jigsaw: Chess Pieces Champion
It may be worth disconnecting battery, doesn't take long after all, and then let the car relearn again - although be prepared for a strange driving experience during this process...
See you next Tuesday
Stu DemonD is offline Reply With Quote Quote
Old 30-09-2004   #4
Give it GOOD TRASH down motorway. The cataylic converter has probably built up a lot of unburn fuel due to faulty lambda.
FiatExpert is offline Reply With Quote Quote
Old 30-09-2004   #5
Trader Rating: 1
i thrash it everyday! lol.. but i will a bit more with the new sensor.. maybe that will help..
Old 30-09-2004   #6
HP
I was only doing 80...
HP's Avatar
HP has donated!
Have you an induction kit fitted? In my experience this usually raises the emissions at idle a little. The silver one has been borderline 3 years running.
Resetting the ecu is a little more complex than disconnecting the battery though, the procedure is explained in the Haynes manual but I could regurgitate it for you if you need. If it runs ok, I wouldn't bother as it will adapt on the fly to anything new. Only time I found it useful was when I fitted the 1242.
Pete.
"Make something idiot proof and someone will just go and build a better idiot".
HP is offline Reply With Quote Quote
Old 01-10-2004   #7
Trader Rating: 1
cheers pete!
nah theres no induction (insurance)
ill just leave it then i think... it runs really well so theres no point i guess.
cheers guys!
Old 03-10-2004   #8
I had same problem on my Cinq, faulty lambda sensor, it wouldnt let the car idle at the right rpm for the emissions test, car was running fine but had to change the sensor for the MOT
crayon is offline Reply With Quote Quote
Old 03-10-2004   #9
Could put some carbon cleaner in your petrol to clear the engine out and just give it a good thrashing 6k or if ya feel lucky bounce it off the limiter. The question is do ya feel lucky. Well do ya punk
MotorWorldChink is offline Reply With Quote Quote
Old 03-10-2004   #10
Winning
GhostWKD's Avatar
GhostWKD has donated!
Quote Originally Posted by MotorWorldChink
some1 watches too much tv
GhostWKD is offline Reply With Quote Quote
Old 03-10-2004   #11
Trader Rating: 1
lol!
Thread Tools
(T) MOT - Leaking Drive Shaft Sei-Mad Cinquecento / Seicento 7 20-02-2005 00:29
No MOT question HornetUK Lets Talk FIAT 12 03-10-2004 19:47
MOT Fail boxes HornetUK Lets Talk FIAT 7 15-08-2004 02:55
(T) MOT Retest Results........FAILED! mdsremos Cinquecento / Seicento 15 25-06-2004 23:10
(G) Fail MOT on this? Jonna83 Cinquecento / Seicento 2 02-04-2003 18:58
