Old 07-08-2008   #1
Trader Rating: 1
craigb244 has donated!
spankthemonkey Champion
cinq handbrake to fly-off handbrake
been hitting a few oil drums while using the handbrake due to the ratchet. so today I stripped and worked out how to make work the oposite to the standard handbrake. looks ugly but works brilliantly!
ID:	48292   Click image for larger version
1997 - White - Cinquecento - PPC featured High boost 16v Turbo
2010 - White - Punto evo GP
craigb244 is offline Reply With Quote Quote
Old 07-08-2008   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: cinq handbrake to fly-off handbrake
Spot on, in the word of Mr Punch, thats the way to do it.
PD
Old 07-08-2008   #3
Trader Rating: 1
glad you approve!
Just tested it and it all works as it should. So I whipped it back off welded everything better and cleaned/lubed everything.
heres a clip of it in action incase anyone has not a clue what it is.
Old 07-08-2008   #4
Trader Rating: 1
nice,shame its not hydraulic tho
Brooky is offline Reply With Quote Quote
Old 07-08-2008   #5
Trader Rating: 1
Quote Originally Posted by Brooky View Post
not to botherd really. I have rear discs and will only use it about 10times at an event so not really going to stretch the cable enough to notice.
Old 07-08-2008   #6
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Rear drums are great for autotesting as they don't overheat on short runs. the discs are better for heat dissapation.
PD
Old 07-08-2008   #7
Trader Rating: 3
ycming has donated!
hmm care to explain the reason doing that ???
Ming
Wanted : Nothing at the moment
ycming is offline Reply With Quote Quote
Old 08-08-2008   #8
Trader Rating: 1
Quote Quote:
I know about that but I also plan on doing sprints. Im going to get a set of new pads for the rear then do some work to get more leverage. at the min I can only pull it up 3 clicks before its solid... hummm
Quote Quote:
auto testing. going around a course laid out with cones as quick as you can without hitting any cones or taking the wrong test... which is pretty hard at speed on the complicated ones.
anyway the point in the hand brake is on sharp turns (U-turn around one cone or even going around a small group of cones more then once) you can keep the power on (wheels spinning) while regulating the speed with the handbrake. doing this with the handbrake while holding the button in is a pain in the arse. and usualy locked with me unable to release the brake quick enough. (causing you to spin the whole front of the car around the back end taking out a ton of cones :P)
*edit* Its also good when pulling away on a hill or from lights (ahem) as you dont have to hold the button while pushing the lever to the floor. you just flick it up and away you go
Old 25-09-2009   #9
Serbia
not meaning to sound like a party pooper, but is that street legal?
nmrmak is offline Reply With Quote Quote
Old 25-09-2009   #10
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Quote Originally Posted by nmrmak View Post
Yup, completely legal.
SPD
Old 25-09-2009   #11
Serbia
Thanks and sorry for revining an old thread, only notice after i already made the post.
Old 25-09-2009   #12
Trader Rating: 1
A lot of the old brit cars worked this way.
my mot tester said it was not legal and i argued the toss.
its a mechanical means of securing the car...
Old 25-09-2009   #13
Hydraulic fiddle brakes are great (one for each rear wheel. But not mechanical so not legal as handbrakes.
DaveMcT is online now Reply With Quote Quote
Old 26-09-2009   #14
CLXCraig has donated!
Is it possible to run both. hydraulic for sprints and tests, then mech for MOT purposes? would be a pain to do i expect.
'93 Panda Mk2 CLX
'11 Octavia vRS
CLXCraig is offline Reply With Quote Quote
Old 26-09-2009   #15
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Quote Originally Posted by CLXCraig View Post
Not really that difficult, using a seperate master cylinder on your existing handbrake lever.
SPD
(T) No handbrake warning lite when handbrake is applied. PUNKTO Punto (Mk2/2b) 8 18-05-2007 18:54
(T) cinq Sporting handbrake sandym Cinquecento / Seicento 10 26-08-2006 15:25
(T) How do you get a decent handbrake on a CINQ? remodan Cinquecento / Seicento 2 04-11-2005 17:49
(G) Cinq HANDBRAKE...HELP Grevsy Cinquecento / Seicento 19 29-10-2005 21:30
(T) Cinq Handbrake Help Liam Cinquecento / Seicento 12 15-10-2004 22:23
