Hi folks,
Having a poke around inside earlier I came across a small patch of rust under the back seat where the floor meets the wheel arch (passenger side).
Anyway, I gave it a scrape with a view to touching it up etc, but while I doing so I was able to poke a small hole through to the wheel arch itself.
So, Ive tidied it up as best I can and put a liberal coating of KURUST on it both from the inside and from under the wheel arch.
If I now fill this hole and paint it on the inside and waxoyl it under the arch etc, will it cure it do you think - or will it need cutting away and re-welding??
I hope its the latter, as is the only real rust on the car from what I can see??
Thanks,
PS The actual hole is the small darkest area in the centre of the dark patch on the photo. It might look worse than it is as the KURST stuff has made it all go black!?
Thanks,
