Hi DET500, I wasnt aware the gearbox had to be physically removed for this conversion?? Can you confirm?Hi i am currently doing a conversion at work (1st one), Have found it much easier to remove dash as glove box type pocket restricts access to left servo mounting and as car has power steering this also requires dash removalas it obstructs the motor.Entire brake pedal assemblie removed this afternoon and tomorrow new pedal assemblies then out with gearbox as clutch lever faces the wrong way . roll on the weekend.
