- Feb 16, 2005
- 5,983
- 988
About 1000 miles before i dropped the new engine in, I had the head gasket go, detailed in another thread.
I took the head of skimmed etc, and refitted new plugs, water pump, thermostat, tensioner, and cam belt.
The head was still leaking so I did it again, and refitted but it carried on with a drip, that's why i changed engines.
I went to investigate the cam sensor on the old engine today, so I pulled the covers off and was faced with the below
As you can see, there is cam belt fibre over the casing, the teeth are missing and chewed up badly!!! What on earth could cause this too happen. I think the tension was fine on it!
I can't belive it did that in 1000 miles, and that it was still runnign fine aprat from the leak!
All I/ can think of is that the water pump was wrong and didn't mate up with the belt??!!! The belt seemed fine with the teeth on the cram and cam pullies?!
Any takers? Just out of curiosity really. I'm going to be breaking or selling the old one anyway
Kristian
Kristian
