Thread Tools
Old 28-04-2007   #1
Unhappy Power steering fault? won't start
Hi , I bought an 02 Seciento for my wife who is learning to drive. Ive only had it 3 weeks and only used it 2 times in that time. tonight i was going to take the mrs out fr a lesson but when I tried to start it up nothing happened. The power steering fault light comes on and stays on and it wont start. it doesn't do anything.
I tried turning the ignition off and trying again loads of times but no luck. Also took the fuse behind the battery for the power steering out and put it back in but this didn't help. I thought the car would still start if there was a problem with the power steering?
any ideas?
mattylamb is offline Reply With Quote Quote
Old 28-04-2007   #2
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Power steering fault? won't start
Nothing happens
Does ngine turn over?
Old 28-04-2007   #3
no it doesn't turn over!
Old 28-04-2007   #4
Forum Moderator
T14086's Avatar
T14086 has donated!
check battery,battery supply,main earths & go from there.
Old 28-04-2007   #5
ok, though wouldn it turn over even if battery was nearly dead? plus the lights still come on.
Old 28-04-2007   #6
Forum Moderator
T14086's Avatar
T14086 has donated!
Not if engine earth was down,lights etc would still work through body earth.Gotta start somewhere so start at easiest & most logical places.
Old 28-04-2007   #7
ok thanks, I'll check it out in the morning. Cheers for the advice?
Old 28-04-2007   #8
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Simple check. Put lights on. The try and start car. If the lights go out the battery is flat.
The power steering light will come on until the alternator starts providing power, which it won't do until the engine is running.
D
Thread Tools
(T) Power Steering?! 1.8Stilo Stilo 6 27-01-2011 20:10
(G) power steering kellym Punto (Mk2/2b) 15 04-02-2007 23:42
(T) please help! power steering failure Suz359 Punto (Mk2/2b) 19 23-07-2006 15:53
(G) Fiat year:95 uno Start plus 14 ie - potential for power steering? charton Uno 26 01-03-2005 13:37
