My Cinquecento has an intermittent fuel pump wiring fault. The pump works, If I test the connector that goes into the pump with a multimeter, sometimes there is current, sometimes not. I shaved back a bit of the insulation sleeve around the wire just before the connector and the fault is still there so the connector is ok. The relay clicks on and off regardless of whether there is current at the connector or not. I have checked and cleaned the 2 earth points behind the headlamps and the one where the battery earths and they are shiny. Any suggestions on where to look next gratefully received. Thanks.
