dot3
even dot4 isnt good enough imo. i only use dot5. the main noticable difference is how sharply the brakes react to pedal movement. although i wouldnt think that could cause bleeding problems. i've never seen the fluid get darker for no apparent reason. thats strange!
maybe its time to use a bleed kit, they have one way valves so when you pump air out, fluid will be sucked in by the master cylinder when you relase the pedal. it seems this isnt happening now because when you release the pedal air is going back in through the bleed nipples.
if you havent got a bleed kit and cant get one (only cost £1.99 in uk) then try this using 2 people:
open front left bleed nipple
press brake pedal
close bleed nipple
release brake pedal
press brake pedal
close bleed nipple
release brake pedal
press brake pedal
close bleed nipple
release brake pedal
press brake pedal
close bleed nipple
release brake pedal
press brake pedal
close bleed nipple
release brake pedal
now see if the brake fluid level in the reservoir has dropped. if it has, do the same on another bleed nipple, until all 4 have been done, making sure you keep the reservoir topped up so fluid is above min at all times.
if this doesnt work, try feeling for air coming out the bleed nipple when you press the pedal, and air getting sucked back in when you release the pedal with the nipple still open. if you fell any air flow or pressure it means the master cylinder is working, it just cant get a supply of fluid. if that happens i would try pressurising the reservoir while repeating the bleed procedure mentioned above. to pressurise it you can use a bottle which fits in the brake fluid reservoir filler cap hole (add a bit of tape to make it an airtight fit), cut a small hole in the bottom of the bottle and blow hard into it when the pedal is released with the bleed nipple closed. hopefully this should force the fluid into the master cylinder. once you get some fluid in the master cylinder it should build pressure and start to take fluid without any help.
there is another option, buy me a plane ticket to the caribbean for a 2 week holiday and i'll bring a whole box full of parts and fix it for you
