Old 15-01-2006   #1
pass side elec window so slow going up
can any 1 help my pass side elec window is so slow going up and down im sure it goes back wards,,is there any thing i can do to make it go faster like is should,,any help would be great ,,,
,[ToNe],
bravo. 2.0 20 v,155 hgt
sutty2tone is offline Reply With Quote Quote
Old 15-01-2006   #2
zombie nation
Hellcat's Avatar
Trader Rating: 3
Hellcat has donated!
Re: pass side elec window so slow going up
Try spraying silicon lube up the channels first. If that doesn't cure it then you need to take the door panel off and look at re-aliging the window mech or replacing the motor.
Drives: Fiat Multipla Eleganza , Owns: Alfa Romeo 159 2.4JTDm
Hellcat is offline Reply With Quote Quote
Old 15-01-2006   #3
well i didnt have that i used a bit of wd40 ,,it goes down fast now but now goes even slower up..,,but thinking ya right door panel to come of,,is it a hard job to sort
,[ToNe],
Old 15-01-2006   #4
zombie nation
Hellcat's Avatar
Trader Rating: 3
No idea on the Bravo. Probably a few screws (in door handle and door tray) and then a load of clips. Got a haynes manual? They're usually good at the interior stuff.
Old 15-01-2006   #5
well i try and have a go ,,lol if it goes wrong il be bac on,,,,,,thax m8 for ya help ,will now go and buy some silicon lube and try that to,,and wipe of that nasty wd40 lol
,[ToNe],
Old 15-01-2006   #6
Trader Rating: 1
T.E.D. Jordan has donated!
I would also try posting in the bravo/a section as you may get more replies hopefully, as more owners of your car will have had the same problem.
Total Engineering Developments
T.E.D. Jordan is offline Reply With Quote Quote
Old 15-01-2006   #7
Cocoon Island Champion, Cupids Crush Champion, Crazy Pinball Champion, Pinball 7UP Champion, Rotamania Champion, Starsky n Hutch PinBall Champion
there are if i remember rightly two different sized allen bolts to remove as well as the screws. if the window appears to push backwards, then its up against resistence. as hellcat says, silicone spray is the answer or you can use dash spray[basically the same stuff].check the channels at the bottom for any crud. and make sure the surround channels are straight and clean before spraying.
sumplug is offline Reply With Quote Quote
Die Hard!!! The Negotiator Leisure Lounge 27 24-04-2006 22:20
SLOW SLOW SLOW ben Latest News 99 30-07-2004 21:22
(G) Lines on passenger side rear most window stubie Ulysse 6 29-11-2003 02:06
(T) Punto mk1 side window PowerLee Punto (Mk1) 1 22-11-2003 23:46
(T) Passenger side central locking and electric window Sando Cinquecento / Seicento 4 29-10-2003 01:57
