![]() | #1 | ||
Posts: 48 Thanks: 0 Trader Rating: 0 ![]() | Fiat Brava 1.6 ECU OBD2 port location So I have tried to find the ECU port location for my Fiat Brava 1.6 year 2000 right hand drive. Looked behind the fuse cover to the right of the steering wheel, removed the small side panels on the central tunnel underneath the console, looked in the fuse boxes in the engine bay but no luck finding it! Does anyone have any idea of its location? The injector light is coming on from cold but once engine is warmed up stays off, so may not be an injector. Reading any codes would be useful! Any help much appreciated!
![]() | #2 | ||
Posts: 26,381 Thanks: 1014 Trader Rating: 0 ![]() | Re: Fiat Brava 1.6 ECU OBD2 port location See marea section.. I put pics in there ![]()
![]() | #4 | ||
Posts: 26,381 Thanks: 1014 Trader Rating: 0 ![]() | Re: Fiat Brava 1.6 ECU OBD2 port location https://www.fiatforum.com/bravo-brav...ml#post4350122 Its possible at 2000 your brava is OBD1 So a 3pin plug under the bonnet..
![]() | #5 | ||
Posts: 48 Thanks: 0 Trader Rating: 0 ![]() | Re: Fiat Brava 1.6 ECU OBD2 port location https://www.fiatforum.com/bravo-brav...ml#post4350122 Its possible at 2000 your brava is OBD1 So a 3pin plug under the bonnet.. There are two fuse boxes under the bonnet. One is located on the bulkhead left of centre (as you look at it from the front), another to the right side next to the top of the suspension strut. I'll take a look and see if I can find it.
![]() | Csoulby | Punto (Mk2/2b) | 2 | 21-06-2017 00:58 |
![]() | Neil8up | Cinquecento / Seicento | 6 | 14-01-2016 12:40 |
![]() | craig20102010 | Bravo | 4 | 29-09-2011 13:45 |
![]() | maximoke | Bravo / Brava | 1 | 17-07-2010 21:12 |
![]() | bennym | Bravo / Brava | 3 | 08-02-2009 17:17 |
