ok so recently brought a mk2 bravo sporting, guy i brought it from was a real hand pump, anyhow long story short its got problems, firstly heater only works on full power and cant seem to locate the heater resistor, secondly having overboost problems, did the usual map clean, egr clean blah blah, anyhow stripped off the turbo cover and vanes are free moving, theres a slight bit of play in turbo approx 1mm all round without oil pressure so im not overly bothered any how reason for this post is, maf hosuing bolts were jammed in and just twisted. after a big war i had to remove entire air filter housing upon doing so pulled off the air filter and you would not belive what i found..
3 dead shrivlled up mice. well 2 and 1 was in 3 bits. i nearly fell over myself when i realised what they was, how the F**k does someone not see them upon servicing the car they had clearly been in there some years, anyhow no shops were open so could not purchase new air filter or maf so poor car is still in hospital until tomoz or maybe monday
