Thread Tools
Old 17-01-2011   #1
m20b25 has donated!
Ireland
Window problems
Its a simple one, window goes down but wont go up on my Bravo. New switch, still dosent work. Do the window regulators give much problems if the car has been standing for a while? Also where are the relays for the windows? Cheers people
The ultimate driving machine, the real M20B25
"Ride me sideways"
VAN-dalised Bravo
Small, fuel economic, environmentally friendly Alfa
I am this gombeen
m20b25 is offline Reply With Quote Quote
Old 18-01-2011   #2
Re: Window problems
My daughters Bravo had the same issue.
Relay is the big black one at the back of the glove box on the nearside. It also opertaes the sun roof, so it's not likely to be that.
Use a flat screwdriver to lever the switches from the door panel. Should come out quite easily.
Check the power SUPPLIES to the switch. The 2 outer ones should be live with the ignition on, IIRC. Try "shorting" the switch. If the motor whirs into life hit Ebay for a new switch (you can't dismantle them --- I've tried).
If not then try the big cable where it comes into the door. Twist the nut and disconnect it. Clean the connections you can get at. Plug it back and there should be a decided "click" when it goes back.
Still not working? Remove the door card. On my daughters the plug had worked it's way off the motor. Spot of superglue and some tape sorted it.
Hope that helps.
Thanks m20b25 thanked for this post
John Mc is offline Reply With Quote Quote
Old 18-01-2011   #3
m20b25 has donated!
Ireland
Re: Window problems
Quote Originally Posted by John Mc View Post
Hope that helps.
Thank you for the help. I tried yet another switch, its still the same. Theres clicking from the relay when I press to go down but nothing when I click up, I'm guessing that the motor has had it. The window is fully down so it wont be easy getting it up I will test the motor as soon as I can
"Ride me sideways"
VAN-dalised Bravo
I am this gombeen
Old 20-01-2011   #4
Re: Window problems
Im having issues with my passenger window. Only got the car in august and when i had went to view it window went down but not up. The guy said he would replace the motor so when i picked it up all was well. Now just recently the window wont go up or down!
Daviedaly is offline Reply With Quote Quote
Old 28-01-2011   #5
m20b25 has donated!
Ireland
Re: Window problems
Ive sourced out my problem. It was the resistor and door loom The plug at the door was badly coroded and the pins are weak. This may have caused the resistor to fail.
To anyone out there with window problems I'd say check out the door plug first
"Ride me sideways"
VAN-dalised Bravo
I am this gombeen
Old 30-01-2011   #6
Re: Window problems
mine are slow even though they run smooth so i reckon a resistance problem were is this magic plug?
clock34 is offline Reply With Quote Quote
Old 11-02-2011   #7
Re: Window problems
Quote Quote:
There's a thick bunch of cables that comes out of the door pillar by the hinges.
It goes into a plug / socket mounted on the front edge of the door.
Twist the nut and disconnect it. Clean the connections you can get at. Plug it back. There should be a decided "click" when it goes back.
Old 16-02-2011   #8
m20b25 has donated!
Ireland
Re: Window problems
Right, to all out there, I've replaced the door loom
And guess what...?
It still doesn't work right!!!!
Its actually the plug thats at fault, not the loom. This isnt easy to change, I'll put up pics if I cure it
"Ride me sideways"
VAN-dalised Bravo
I am this gombeen
Old 18-03-2011   #9
m20b25 has donated!
Ireland
Re: Window problems
I forgot to update this, whoops
To cut a long story short, I replaced the loom going into the car and that solved that
Still working perfectly
"Ride me sideways"
VAN-dalised Bravo
I am this gombeen
Old 18-03-2011   #10
Denmark
Re: Window problems
Amazing work there - Nice photos - Thumbs up
Izo is offline Reply With Quote Quote
Old 22-07-2013   #11
Re: Window problems
where is the connector gor front driver side ive fixed the rear as u showed but cant find the front connector..help
HONESTRAB is offline Reply With Quote Quote
Thread Tools
(T) electric window problems please help!!!! tetleys Stilo 14 15-02-2012 21:42
(T) window problems cento-boyo Cinquecento / Seicento 5 15-05-2007 21:22
(G) Electric window problems Dave G Ulysse 12 22-12-2006 19:56
(T) Help! Window problems T.E.D. Jordan Punto (Mk2/2b) 3 04-08-2005 02:27
Window problems... Sando Lets Talk FIAT 3 19-06-2003 20:54
