Will chopping my airbox as they say or drilling it make my car grunt more also will it effect anything and cause problems much feedback appreciated thanks
cheers (Y) could you giv me sum more advice please
Jus wondering if anybody could give me sum info please. Iv got a 1.2 16v w reg bravo and has done 61,000 miles do u think it is in need of a timing belt cam belt and tentioners? And whatvprice am i looking to pay,,, much appreciated thanks.
Don't bother messing about with the airbox. First step is to check you can get the lid off because the bolts always seem to seize up in the bottom of the box. Then at least you can put a clean filter in.
Best straightforward improvement is a K&N panel filter with the standard airbox. You can then use the ECU reset procedure to let the engine learn the new characteristics.
