adrianclerical
I recently had the misfortune to have the fuel pump stop working. OK - I got a 2nd hand one eventually. Unfortunately it had been exposed to the elements and the nut which holds the breather pipe elbow to the pump body was seized and the only way of sorting things was to cut off the old remnant of breather pipe.
I've managed to (eventually) get the plastic ring nut undone and swapped over the pump bodies ok. All was reconnected ok with the exception of the blue breather pipe connection. The pump works fine and the engine runs again without any problems.
The big problem is how do I get the existing blue breather pipe onto the pump body elbow? It appears to be a heat shrink pipe so my usual idea of heating it up to make it pliable isn't a good one. I've tried brute force and ignorance but that doesn't work. I did see a hint on the web about using point nosed pliers to gently make the diameter of the pipe bigger enough to push onto the elbow but I just couldn't make sufficient difference without risking breaking the existing pipe. I did try washing up liquid but that didn't seem to make any difference. It would help if there was bit more working room as well.....
Any ideas or thoughts please?
