Never had a temperature problem with my Bravo until today. Got caught in traffic and I noticed that my temp was just above normal (half way) few minutes later its right up to red, then back down but still hotter than normal. So the symptoms are: temp is ok until just above normal then the needle goes crazy, its all over the place, I watched it and it jumps a dot in a split second then down again then shoots back upto the red! I cant work it out, speed doesnt really help either, and fan normally comes on at half way, it still does this to a point but it seems to stay off until its in the red!
Looked at the coolant and its fine, bleed the system until all screws are leaking coolant. Hasnt helped at all, sat on drive and all was fine until it hit normal temp, then the needle shoots all over the place, but seams to like the red the most.
Any ideas? Thanks
Any ideas? Thanks
