Comment
Guide Tools
<!-- google_ad_section_start -->Fitting Bravo 2007 washer jets to your classic Bravo/a and Marea<!-- google_ad_section_end -->
Published by Adrian Bravo
20-03-2009
Unrated
User Rated:Unrated
A quick mini guide for a fantastic upgrade to your washer jets.
There are two versions of the Bravo 2007 washer jets. One has a heating element and the other does not. Both include 27cm of rubber tube.
Now I got excited and thought cool heated washer jets. Unfortunately the housing for the heating element is the part you have to cut off to make the jets fit your classic fiat.
What you will need
2x Bravo 2007 washer jets.
Junior hacksaw maybe a small file if you weren’t too precise.
I would buy two non-heated jets because it is a lot harder to saw through the heating element.
Old vs New
You can see how similar the jets really are. The new one has a sleeker lower profile and a nicer finnish.
Highlighted in red is the bit you will need to cut off.
I made two cuts you can see the heating element in the second pic that I had to cut through.
The other difference is the neck. The original is 90 degrees the new is 45 degrees. Not a problem though. You can pull the neck's off and use the originals or just swivel them around.
The new nozzle does not have vertical adjustment, but hits the windscreen in just the right place.
There you go a quick guide. Good Luck.
Old 29-05-2009   #1
Re: Fitting Bravo 2007 mist washer jets to your classic Bravo/a and Marea
is there any problem with them, not being adjustable? are they "shooting" at the right place?
Fiat Marea SW 1580 16V ELX 182A4000 10/96
nullzero is offline Reply With Quote Quote
Old 29-05-2009   #2
Speedbump grimacer
Adrian Bravo's Avatar
Trader Rating: 1
Adrian Bravo has donated!
Quote Originally Posted by nullzero View Post
They are perfect. you wont be disappointed
Adrian Bravo is offline Reply With Quote Quote
Old 25-06-2009   #3
Speedbump grimacer
Trader Rating: 1
Pics of them fitted to my 1997 Bravo
Old 17-07-2009   #4
Italy
Nice and very simple mod...
I have tried another way...
FIAT Coupè washer jets! They fit directly on the wiper arms and have 4 jets each (the upper two are adjustable)
The best thing to do is fit the jets on Bravo's arms, because Coupè arms are little different in shape and lenght.
Simply remove the old water pipe from the wiper pump, connect a new one and put it under the plastic cover between engine bay and the windshield. Drill 2 little holes near the wiper arms and connect the 2 wiper pipes to the new pipe with a Y valve (i have removed the valve mechanism, as the pipe lenght is not so big and the valve will reduce water flow).
Advantages:
-Water arrives directly on the wiper blades, and continue to follow the blades also when you turn on the wipers (no more wipers scratching the dry windshield!)
-If you close the original washer holes on the hood and repaint it, you will have a nice and clean looking hood
-Water arrives exactly where you want at any speed (windspeed usually cause water to hit the windshield in a lower place)
PS: actually i have removed the rear wiper, and used its exit on the pump for the Coupè washers, without removing the original ones on the hood. So actually i have 16 washers on my windshield
Quetzalcoatl is offline Reply With Quote Quote
Old 19-07-2009   #5
Italy
Here is a photo of my wipers, equipped with Coupè washers.
Old 19-07-2009   #6
Speedbump grimacer
Trader Rating: 1
Thanks for the info looks good
Old 29-12-2009   #7
Ireland
dose the 2007 bravo washer jets squirt a mist of water at the window insted of a jet of water???
alan2009 is offline Reply With Quote Quote
Old 23-02-2010   #8
Turkey
you did it really well, congrugulations
now i'm thinking of doing the same to my marea
thank you
avcihuan is offline Reply With Quote Quote
Old 02-03-2010   #9
brillant guide
worked perfectly
cheers
Marshall147 is offline Reply With Quote Quote
Old 03-03-2010   #10
Speedbump grimacer
Trader Rating: 1
Quote Originally Posted by Marshall147 View Post
brillant guide
worked perfectly
cheers
Thanks for the feedback, cheers
Old 05-11-2010   #11
Speedbump grimacer
Trader Rating: 1
Re: Fitting Bravo 2007 washer jets to your classic Bravo/a and Marea
Some feedback
Quote Originally Posted by Layth View Post
Adrian/Si, I put the new 2007 Bravo jets on today, took about 5 minutes in all and I'm really pleased with the outcome, spray is much better than the originals. I sliced the extra plastic off with a Stanley knife and it was a superb fit. Would recommend to everyone. Cheers.
Old 16-01-2011   #12
ATM my bravo ones at the front as being odd, the passenger side is on but drivers side has stopped spraying....
Im a novice at car stuff and this quick guide I don't get, how do u take off the old ones and fit the new ones...?
mark2004uk is offline Reply With Quote Quote
Old 16-01-2011   #13
Speedbump grimacer
Trader Rating: 1
Quote Originally Posted by mark2004uk View Post
I would follow the pipes and check the Y splitter first.
It is very easy to remove the old ones mark.
If you pinch the two plastic clips toghether, by hand or with large pliers or mole grips that will let you push the jet upwards out of the bonnet.
Old 16-01-2011   #14
Quote Originally Posted by Adrian Bravo View Post
Ok, Where is the Y splitter?
Comment
Guide Tools
(G) Windscreen Washer Jets - Mist Type JoskeJTD Stilo 25 14-12-2009 00:07
