How to use Blue and me functions with aftermarket headunit
i mentioned this on a previouse post, so heres how i did it.
its so simple, the best cable to use costs a pound from ebay including posting.
it will only work this way if your h.u has a rear aux port.
once its all connected, b&m will only work when in aux mode.
if the phone rings, it will not ring out through your speakers unless in aux mode!
get your self one of these or somthing with a 3.5mm jack (earphones work but are hard to strip the cable and cause interference/crackeling!
http://cgi.ebay.co.uk/3-5mm-jack-to-jack-with-1-2m-Cable-for-iPod-MP3-Device_W0QQitemZ250505201702QQcmdZViewItemQQptZUK_Computing_LaptopAccessories_RL?hash=item3a53460826&_trksid=p3286.c0.m14
-cut the cable in half, you only need one half!
-strip the outer insolation of the cable to expose the inner cores
-seperate the earth and the black and red core
should look like this:
then connect the red to left, black to right and the other one to earth (middle one).
i just pushed the striped ends in the plug, not particuly good practice, but as long as you have a good connection it shouldnt cause problems.
the correct way to do it would be either to get the female housing of the mini iso plug and then connect the aux cable to that, or cut the plug off and connector block or crimp the cables!
plug into the headunits rear aux and all done.
sorry if i posted in the wrong section then.
not sure if this is grande punto specific or same goes with other cars with blue and me!
im using this on a pioneer h.u, i tried it on my mutant h.u and if i was in say cd mode, and the phone rang it automacicly switched to aux.
so im geusing that some h.u's recognise when a aux signal is sent and automatically switch to that mode.
the pioneer doesnt do this:bang:
£13 cable?
that 99p inc postage cable is enough to do 2!
i can even post the other half of mine if someone hasnt got an ebay acount!
cant say as ive got any sugestions as to the auto muting.
is the auto mute signal just a live that is activated when needed?
Tried lots of combinations with live and earth activated radio mutes but still no joy, i'm soooo close i think.
will the headunit automatically change to aux input if the phone rings. Which headunits can do this. and what about the steering audio controls how to get them work with new aftermarket Headunit
coulpe of things ive noticed after using it like this a few weeks, when the phone rings, it doesnt ring through the blue and me, in only mutes whats been played and comes up on screen.
and theres no way of adjusting the external volume, so when you switch from blue and me to cd or tuner its very loud!
