A andrew69 New member Joined Oct 7, 2014 Messages 8 Points 6 Oct 7, 2014 #1 Hello, I have on dashboard lighting ESP and ABS. I scanned for faults and showed code: B0F40 Maybe someone could tell me what it means ? Because I can't find on internet... Thanks.
Thunderbug Established member Joined Sep 10, 2010 Messages 599 Points 214 Location North Hampshire Oct 7, 2014 #3 andrew69 said: Hello, I have on dashboard lighting ESP and ABS. I scanned for faults and showed code: B0F40 Maybe someone could tell me what it means ? Because I can't find on internet... Thanks. Click to expand... If your APE is under warranty take it to a dealer & they can sort the problem out for you.
OP OP A andrew69 New member Joined Oct 7, 2014 Messages 8 Points 6 Oct 7, 2014 #4 nop the APE is not under warranty...
Mkala Established member Parked in the garage Joined May 10, 2012 Messages 724 Points 204 Oct 13, 2014 #5 Which scanner gave you this code ? "Universal" type of MultiECUScan ? Seems not a lot of thing about this code
Davren Moderator Staff member Uploaded 10+ resources/downloads Joined Jul 6, 2008 Messages 16,366 Points 3,858 Location London, UK. Oct 13, 2014 #6 Some code readers give codes in hexadecimal that then need to be converted to decimal. B suggests it's a body code and 0F40 hex = 3904 decimal, giving the code B3904. Unfortunately, I can't find any reference to code B3904. .
