Old 12-02-2020   #1
Straight Through Exaust
As rear exhaust box on 500 Abarth is starting to show signs of age, rust to outer skin, thinking of changing out to stainless steel.
Has anyone fitted an after cat straight through exhaust? How noisy is it, is there any issue in MOT and emissions?
Be good to hear what others have done, don't really want to put same back, as seems rusting outer skin on the back box is an issue
icedup51 is offline Reply With Quote Quote
Old 12-02-2020   #2
varesecrazy has donated!
Quote Originally Posted by icedup51 View Post
The standard 500 has a multilayer back box.. the layers rust..and peel.. with another layer underneath
They tend to last @8 years
What is yours like?
Emissions.. nothing to do with bsckbox.. but NOISE.. well..
Old 12-02-2020   #3
chris3234 has donated!
Re: Straight Through Exaust
It should Be a mot without a rear silencer due to exhaust noise being louder then standard
If it fails orbit is down to the testers opinion
chris3234 is offline Reply With Quote Quote
Old 12-02-2020   #4
Thanks for replies. Seems not a good idea then, so can you just remove the rusted skin and its still deemed OK?
Old 13-02-2020   #5
It's acceptable for mot if the outer is removed or if you just leave it.Any defect has to esult in a major leak of gases' to fail.Re: noise, it depends on the tester as it's entirely subjective (for now) cheers!
yann is offline Reply With Quote Quote
Old 13-02-2020   #6
The condition of the silencer in itself will not cause it to fail an MOT unless there is undue noise or there is a significant leak of gas other than from the tail pipe.
If it's corroded and peeling but is not leaking and the baffles haven't collapsed to cause a racket, then it will appear as an advisory... something like "..silencer deteriorated but not causing any leak of gas..."
I once replaced the cat' back on my old Alfa 145 with a stainless system. I decided it would be a good idea to delete the middle silencer but keep a regular silencer (all in stainless steel) at the blunt end. That was fairly loud I have to say (middle silencer actually does the main bit of noise suppression) and made me a bit self-conscious, although it never got noted at MOT time as being too loud.
Get yourself a stainless system made up, keeping any mid-section silencers your Abarth might have but use a smaller (aka "sport") rear silencer to get you just a bit more fruity. But you need to have a physical silencer for the MOT, as far as I'm aware.. it might fall foul of the new reg's about modifications that deleted (usually DPF in diesels) components otherwise.
Don't peel off any loose skin on your silencer. I think it would look more decreprit than just leaving it as it is, although trimming off any very scabby bits might be a good idea, if it prevents the MOT tester cutting his head on it.. MOT testers are moody enough already, without your car inflicting ABH on them...
And it will appear that you checked the silencer/saw it had no leaks, so he'll know you're on the maintenance... and he won't tell you it's leaking if it isn't.. since he'll know you'll know different.
Ralf S.
No bullets for chaingun
Ralf S. is offline Reply With Quote Quote
Old 13-02-2020   #7
Thanks Guys
Old 13-02-2020   #8
Goudrons has donated!
I've a standard silencer I took off mine, was only on a month.
I've not checked it, but I presume it's still in good nic.
Another option would be a Record Monza in stainless steel (not the cheaper black painted steel one).They sound awesome.
There's a few on ebay around the £250 mark.
Mark sure the valve is free, they are prone to sticking.
Goudrons is offline Reply With Quote Quote
Old 16-02-2020   #9
I have a 500 Abarth with straight thru stainless 2.5inch main pipe and silencer free Magneti Marelli rear stainless twin outlet rear pipes. Passed Mot fine this and earlier years. It's not crazy loud either ...nice burble at tick over. Nice an fruity when you wring it's neck too!!! There's a cool deal on eBay at mo which is what I have. Well made, fits easily....and dirt cheap at £129 delivered. https://www.ebay.co.uk/itm/401791092397
Prontissimo is offline Reply With Quote Quote
Old 16-02-2020   #10
Old 22-02-2020   #11
I have a straight through to original back box, it doesn’t sound to loud,. Pops, grunts and whistles when driven in a certain way.
Stephen A500 is offline Reply With Quote Quote
Old 22-02-2020   #12
typecastboy has donated!
I take beer to my garage of choice at Christmas. A couple of years ago I took a load up and said “none of this is for Chris, he’s failed too many this year”, making sure he was in ear shot.
I did give him some though. Got to keep them sweet.
typecastboy is offline Reply With Quote Quote
Old 22-03-2020   #13
Dennis the menace has donated!
MS Racing do exhausts. This looks reasonable but not sure if it's an MOT pass though.
https://www.ms-r.co.uk/store/p273/MS...Exclusive.html
Dennis the menace is offline Reply With Quote Quote
Old 22-03-2020   #14
Quote Originally Posted by Dennis the menace View Post
Depends on the tester
In whether he thinks it's louder the standard or not
Or if he/she even cares
Old 02-06-2020   #15
USA
The FIAT 500 Abarth comes with a straight pipe standard, so your replacing your straight pipe with a straight pipe?
Rocco Reviews is offline Reply With Quote Quote
Exaust Smoke Gabriel Tiago FIAT Boo Archives 2 01-02-2009 14:06
(G) exaust leak doidge0 Punto (Mk2/2b) 10 12-05-2008 09:34
exaust trim Justin FIAT Boo Archives 9 29-02-2008 00:01
Exaust backbox Dave FIAT Boo Archives 10 01-08-2005 12:41
Exaust Manifold Neil FIAT Boo Archives 0 21-05-2001 13:51
