Thread Tools
Old 09-07-2016   #1
USA
Rear brakes and general ride
I have only had my 2013 500 pop for a few months but i just wondered if anyone else has experienced a slight dragging brake pad sound from the rear. I changed the pads even though the old ones looked OK but no difference. How bad are the factory calipers for going bad? Any advice/help would be appreciated. Gary
eagleswing13 is offline Reply With Quote Quote
Old 10-07-2016   #2
Australia
Re: Rear brakes and general ride
I'm no expert but have you checked the rear wheel bearings?
Daniel Leopardi
Fiat 500f 1970 Red (with tan roof and seats.)
Fiat 500c 2016 Sky blue (with tan roof/tabbaco seats.)
Adelaide. South Australia.
Leo6 is offline Reply With Quote Quote
Old 10-07-2016   #3
varesecrazy has donated!
Quote Originally Posted by eagleswing13 View Post
Hi Gary, and welcome to FF,
the US version varies from the EURO one in so many details.. I cannot say for sure..,
but this is a common issue on the similar spec panda's;
https://www.fiatforum.com/panda-iii/...ar-brakes.html
Charlie - Oxford - UK
Old 11-07-2016   #4
USA
Is there a manual piston adjustment on these vehicles?
Old 11-07-2016   #5
USA
Quote Originally Posted by Leo6 View Post
There is no play in the bearings and with the pads out it spins freely with no drag or noise
Old 11-07-2016   #6
Moderator
Read this post for more information on this common issue. Models with disc brakes at the rear are even more likely to experience this sort of thing.
"Just 'cos you're not paranoid, doesn't mean they're not out to get you"
jrkitching is offline Reply With Quote Quote
Old 11-07-2016   #7
USA
I cleaned everything up and lubed up everything I could I believe.
Old 11-07-2016   #8
USA
I'm starting to wonder whether the rotors may be warped as the ride seems bumpy at times
Old 12-07-2016   #9
Moderator
Easy enough to check with a dial gauge.
I'm not familiar with the parking brake arrangement on US spec cars, but that'd be another thing to consider.
Old 21-07-2016   #10
USA
Quote Originally Posted by jrkitching View Post
So I found out my rear tires were pretty badly cupped. Got new tires and the noise seems to have been fixed but the ride does seem a little bumpy at times, anyone had this too and if so have you had to change shocks (as it can cause cupping also)
Old 21-07-2016   #11
It's always more involved
John202020 has donated!
Rear shocks are cheap and easy to replace it seems that lots of people have had to replace the rears and I've had to do all of them though ours is a 2009
30 years of Honda Accords, now Mazda 6 and a Fiat 500
John202020 is offline Reply With Quote Quote
Old 21-07-2016   #12
USA
Quote Originally Posted by John202020 View Post
Any advise on which shocks to get? Brands/models
Old 22-07-2016   #13
Depends what you can get over there, the rears not fitted by me are KYB excel which I believe are a budget brand, the fronts I've just done I used Sachs with Bilstein springs, Monroe, also make quality shocks here, the reason for replacement was not ride quality but more the fact they had rusted so badly that oil was leaking from one of them, so proper job is to change almost everything, I've just done a how to for the fronts the rears are very easy t replace(shocks) but be careful to not shear off the bolts! as I know to my cost.
You can see the leaking oil on the center of the old shock
ID:	169823   Click image for larger version
Thread Tools
(G) Abarth 500 ride height vs normal (Sport) 500 ride heigh fpan Abarth 500 0 16-12-2015 15:10
(T) Random front brakes smelling with hot rear brakes sticking on, random loss of engine iangray100 500 10 23-06-2015 19:31
(T) Rear Ride Height 2668GRIFFIN Fiorino (Mk3) 8 19-03-2013 19:42
(T) multiwagon ride height? rear bushes, brakes etc cheddar Stilo 0 03-10-2011 00:51
(T) adjusting rear ride hight StoneNewt Punto (Mk2/2b) 3 16-07-2006 19:38
