I've just been perusing (that's when I put on my reading specs ) the Feb. issue of Practical classics magazine (U.K.). On page 109, there a query about failing condensers. The answer explains how the ignition system operates incl the condenser.
here's the final part :- A condenser is known in electronics as a capacitor ; typically 0.22 *micro*Farads and 400Volt. They're a bit crude by normal electronic standards. you can replace it with a longer-lived 'polyester film' capacitor, which are widely available on eBay. Make sure you buy one with long leads.
There is a picture of one fitted to a distributor - sorry I can't do a scan/upload.
It looks like a brown/orange rectangular moulded blob of plastic - I'd estimate it's size as approx. 20mm x 10mm x 3mm thick - it has 2 plain uninsulated wires coming out, one is connected to the low-tension connection on the distributor (i.e. where the small wire from the coil connects to the contact breaker connection (8mm nut) the other wire is fitted under an adjacent screw as an earth point. Seems simple to install. Being it's an electronic component, I'd imagine it's polarity sensitive i.e. the leads must be connected the correct way round - there's no markings visible on this capacitor the way it's shown installed externally on the side of the distributor.
I know there's several people on here that have considerable knowledge of electronics and hope they'll chime in with their opinions.
I recall many on here have posted having issues with apparent short condenser life - iirc 'the hobbler' has recommended a source of a better quality condenser on a number of occasions.
But would this 'polyester film' capacitor provide a better, more reliable replacement?
*Please note, I've typed 0.22 microfarad above, the magazine says 0.22 followed by a u with a long left leg, followed by F - I can't find the symbol for micro.
Al.
Al.
