- Apr 1, 2017
- 361
- 137
I did some troubleshooting last night. I had the wife start the car, put it in gear and release the clutch, while I looked underneath at the axle shafts.
With the clutch released the right shaft does not spin. The left side shaft spins as does the coupling. This leads me to believe the left side is to blame.
Dumb questions:
1) With the motor off and the car in gear, I'm able to push the car with little to no resistance. It feels like it in neutral. Do you think this a symptom of the differential "disengaging" one wheel while the other side coupling has failed?
2) Even if the coupling on one side has failed, shouldn't there be enough torque to spin the other wheel and move the car via the transmission/differential? Or is this normal operation for the Cinquecento differential?
Again, grazie mille for all the assistance.
If the coupling spins and as would the outer part of the damper coupling then that would tell me it's the rubber coupling that's gone, still not a major job but more complex than the slide coupling....
don't worry about been able to push the car whilst in gear, the way differentials work because there is loss of drive to one wheel it will seem like it is in neutral as that one drive shaft will spin rather than turning the gearbox etc....
