What are these holes in the floorpan for? Under the holes marked with numbers 1 and 4 you can see the bracket for rear swingarm. If they are supposed to be plugged, how can it be done because the bracket is partially blocking the hole? What is the use of holes 2 and 4, should they just be plugged also?
