There even used to be an inch and 1/8th S.U.. Iirc it was fitted to e.g. the 803?cc Morris minor. (not much larger than a Fiat 500/650 engine)
www.winsu.co.uk S.U. Needle selection program + tuning software
www.sucarb.co.uk On home page, enter vehicle make and model in box and see details of SU carb fitted, incl. needle used etc. This site is part of Burlen Fuel Services (owner of the SU name). If you enter Triumph Motorcycle it gives details of the carb used and settings.
www.holdenpaedia-oldholden.com/SU_Carburettors This site includes carb sizes and designations (tag attached to float bowl screw), also a very interesting animation of how the SU carb works - this is worth watching by anyone who wants to see how an SU carb works and how simple it is.
The SU carb jet stays the same for each size of carb and will be 0.09" or 0.10" or 0.125" e.g. all 1-1/4 inch SU carbs use a 0.09" jet - its the needle which is chosen to suit the engine (there's 100's of different profiles of needles).
The piston spring (fitted above the piston inside the dashpot) - there's only a maximum of 4 variations for each size of carb. They're colour coded.
Before the availability of 'rolling-road' tuning, there was a system of needle selection using a certain kind of roadtest. This is described here:-
www.tecb.eu/onewebmedia/Tuning_SU_Carbs.pdf is a website that shows a reprint of a book on tuning the SU carb, originally published by Cars and Car Conversions Magazine/SpeedSport motorbooks. On page 31, there is a list of SU carb specs by car make/model, type of carb fitted, rich/std/weak needle options and colour of spring fitted. Page 38 gives an index of 0.09" jet needles listing the step sizes of each needle letter code.
Also,if you switch to an SU carb, you can forget about your idle jet becoming blocked.....
Did I mention that I was a fan of the SU carb?
AL.
