jolly500
Hi all.
I've just assembled another engine and, for the life of me, I can't get it to start. In fact I can't get any indication that it wants to start, not even a cough.
I turns over fine on a new battery and rebuilt starter.
I've had others investigate and we're all totally baffled.
I do have spark and fuel and the timing has been checked and rechecked as have the valve clearance.
So the question, as this engine has been assembled with used parts (totally against my recommendation), what influence can compression ratio have on starting?
I tested the compression and both cylinders show about 4 bar. I want to borrow another instrument to double check the readings.
Should it start with that?
Steve...
Steve...
