im Axle Specialists
Old 12-07-2018   #1
Oil spraying out of exhaust ?!
Hi all!
I have a 72 500, and there is a lot of oil coming out of the exhaust! Spraying all over the place.
Any ideas ??
aaron500 is offline Reply With Quote Quote
Old 12-07-2018   #2
Re: Oil spraying out of exhaust ?!
Are you 100% sure that it is coming out of the exhaust?
For that to happen you would either have some very worn or damaged pistons or very worn valves and guides.
Toshi 975 is online now Reply With Quote Quote
Old 12-07-2018   #3
Lesta Fiat
Hugh Jarce's Avatar
Hugh Jarce has donated!
I should think you will be getting a lot of smoke too?
Hugh Jarce is offline Reply With Quote Quote
Old 12-07-2018   #4
Quote Originally Posted by Hugh Jarce View Post
A lot of smoke ! Turns out it isnít coming from inside the exhaust but spraying from somewhere else onto the exhaust ?!
Old 12-07-2018   #5
Is the oil dip stick missing. It should sit in a hole above the exhaust, by the distributor. If it is missing then oil spits out the hole and onto the exhaust box.
Duffys Dad is offline Reply With Quote Quote
Old 12-07-2018   #6
Quote Originally Posted by aaron500 View Post
Is it just on the exhaust side of the engine? If so it could be From the rocker cover , push rod tube seals, dip stick as mentioned and sometimes the oil light switch can break down and spray out oil. Another common one is the exhaust bracket to crankcase studs coming loose or falling out.
Old 12-07-2018   #7
USA
Aaron,
I had a similar issue. Mine was dipstick related. I have the dipstick with the rubber stopper on the shaft. Over time with heat and age, the hole where the dipstick shaft goes through enlarged. I took the two pieces apart, cleaned them thoroughly with solvent, and then epoxied them together, in essence sealing the hole to the shaft. This solved the problem of oil peeing out onto the side wall of the engine bay and muffler.
Luxe is offline Reply With Quote Quote
Old 14-07-2018   #8
New Zealand
I've certainly had a similar, though more explosive problem. The dipstick is the main suspect.
timgarman is offline Reply With Quote Quote
Old 14-07-2018   #9
Greece
For what I understand dipstick fails very often so maybe securing it with a spring or a piece of wire might be wise.
gordinir8 is offline Reply With Quote Quote
Old 16-07-2018   #10
Switzerland
I had my dipstick coming out today. I always thought that it felt loose. Not sure if came out by it self or not. I did check the oil level before the drive so it might have been my fault and yes it smokes a lot when it is not in place.
Jocke.
vij is offline Reply With Quote Quote
(T) Oil in Exhaust earl34 Ducato 20 23-06-2015 00:47
(T) Stilo oil dipstick keeps popping out and spraying oil jiffy995 Stilo 7 22-03-2013 21:48
(T) done oil change and exhaust is now really smokey mk2 2000 Punto (Mk2/2b) 4 02-05-2012 17:30
(T) Oil in exhaust gas???? Please Help! madbri Multipla 2 04-08-2010 17:53
(T) oil out of the exhaust daisy Cinquecento / Seicento 3 03-05-2005 17:50
