El cargador
Member
My wheels nuts are coming loose.I had the original wheels shot blasted then powder coated grey/silver and they were ok until I decided to change colour. As the wheel nuts aren't like modern ones with a conical design I fitted spring washers which dug into the powder coating.so I sanded down where the nuts tighten up and sprayed them white. When I was out the other day 2 days later something started knocking,turns out the wheel nuts had come loose so I re-tightened them and they're starting to loosen again. I have cleaned the hubs and rear of the wheels.
Are they fitted with washers or should I put a bit of "lock thread" on them? I am cuatious as I had 2 snap whilst taking them off as I'd put lock thread on(maybe I overdid it)
