124spiderman
Member
Hiya,
Since my 650 conversion engine rebuild, I've done a little over 1500kms. I've notice I've since developed a serious oil leak from the rear of the engine. At first I suspected the sump gasket, replaced it but still leaks. The only other places that I can think is Rear main "O" ring (main bearing loose??) or rear main seal. Both of which are supposed to be BRAND NEW. I'm going to pull the engine out either way, but does anyone have any other idea where the oil is dripping from.
Back of flywheel soak, (as is the flywheel cover - it has lots of oil). The back of sump is also wet. Not coming from top of engine as I checked and removed all the tinware. Puzzling.
