topolino2000
- Nov 16, 2008
- 12
- 3
I have a 1972 500 L which has covered a genuine 28000 miles.
It starts ok every time but after about 15-20 minutes it starts to loose power gradually and eventually dies.
It will then not start for about 10 mins until it has cooled down a bit.
I have renewed points, condenser, coil, HT leads, dist cap, rotor arm, needle valve, checked float height, substituted fuel pump for electric one in case pushrod had worn, reset valve clearances to 126 spec (wider) in case they were closing up, removed and cleaned fuel tank and renewed sender unit/pickup, renewed all relevant fuel lines, checked engine thermostat, tried different heat ranges of spark plug etc etc.
Have checked valve clearances within a minute of it cutting out and they are fine. Am running out of thoughts now. Any idea's?
