im Axle Specialists
Old 3 Weeks Ago   #1
Malta
No current to Ignition Coil
Hi all. Accidentally I broke the ignition coil of my x1/9 1.5L 1987.
I was given a new ignition coil but as soon as I started the car, it was not revving properlly i.e. missing - after a minute it stopped. Tried to switch it on to no avail.
Since then, I replaced the coil with another new one from the Parts Shop- the car turns but wont start - there us no sign of firing....infact no spark.
I noticed that there is no current going in the coil...put a dc lamp test on the positive point of coil and turned on the engine.
Is there a fuse or ballast resistor between the ignition and the coil..which might have been blown when I used the wrong coil?
Many thanks and appreciate your help.
Neville Minuti is offline Reply With Quote Quote
Old 3 Weeks Ago   #2
Re: No current to Ignition Coil
Quote Originally Posted by Neville Minuti View Post
Did you connect the test lamp between the coil +be lead and a good clean metal part of engine?
Likes Neville Minuti liked this post
jackwhoo is offline Reply With Quote Quote
Old 3 Weeks Ago   #3
Malta
Quote Originally Posted by jackwhoo View Post
Went again to check..now there is current at the in positive..tried my luck by trying to switching it on...no firing. Thanks
Old 3 Weeks Ago   #4
Check points are opening and closing and that they are clean. If none of those things need fixing, remove the condenser and try a known good condenser.
Measure resistance of primary coil windings
And secondary windings
If you have a multi meter.
Post results
Old 3 Weeks Ago   #5
Before you replace the condenser.
Pull the ht lead that goes from coil to distributor cap off distributor cap, hold end of lead 6 or 7mm from clean metal part of engine , turn engine on starter motor , Do you get a spark between ht lead and metal?
Old 3 Weeks Ago   #6
Hi Guys.
i would look at changing the condenser, they have an annoying habit of working while your testing the car just until you want to drive it then they pack up. just be fully sure you have connected the wires onto the coil the right way round.
Tim
timmycm850 is offline Reply With Quote Quote
Old 3 Weeks Ago   #7
Ireland
How did you accidentally break the ignition coil?
Just curious.....
Al.
F123C is offline Reply With Quote Quote
Old 3 Weeks Ago   #8
Malta
Hi, I tried that and there was no spark. Changed also the ht lead to a new one, but still no spark. Spot on, its here the problem..the only thing that the 3 COILSs are not Fiat or Marelli...thanks
Old 3 Weeks Ago   #9
No its not sure to be coil yet.
The condenser has likely failed.
Change the condenser.
Then look for a spark from it coil lead to metal.
Make sure points open and close(connect your test light to the coil - ve and coil +ve , crank engine on starter , test light should flash on and off)
It does not matter what make the coil is ,
But the ignition coil MUST be from or for a car with contact breaker (points) ignition
NOT for electronic ignition.
There will be a short circuit with coil from electronic ignition.
Do you have a multi meter that reads ohms?
Old 3 Weeks Ago   #10
You need a coil that has a primary winding resistance of about 3ohms
(T) ignition coil 124spiderman 500 (Classic) 1 09-05-2015 23:22
(T) Ignition Control Box issue? Ignition Coil? mtblan0 X1/9 4 21-07-2010 21:49
(T) IGNITION COIL: which one? btret Barchetta 1 24-01-2009 13:48
(T) mk 1 ignition coil kemp2368 Punto (Mk2/2b) 11 31-10-2007 15:07
(T) Need new ignition coil/s imola_fowkes Cinquecento / Seicento 24 29-03-2005 01:01
