Or you could do it yourself... for a tiny fraction of the cost gc would charge.
Oversize valves are available from later fiat models of the sohc, so it's a relatively staright forward job, you will need a good machinist to install the oversize seats for you though.
PBS did use nissan valves with the collet groove recut, overall the valve is shorter, so it required the use of lash caps or a machined cambox.
If you want some decent information about different sohc heads and which ones are best to use and why check out a thread I've written on turbo124.com/forum in the "X19 discussions" forum.
SteveC
