Hello Scotty
well the weather is still holding but I have not had the top off - what a waste!
I am impressed with your perseverance and your in-depth research. Yes please do check out the wiring diagrams if you are inclined; it will be good resource for others who may read this thread.
The dealer installed immobiliser worked by grounding out the coil via the tacho AND tapped into the hazard flasher circuit using Scotch-locks (tell me they are not invented by Scotts, please!). Removing as much as possible of the connections in the rats next above the fusebox was great fun. Not. As you say this may be a source of the issue.
Turning to the flash to pass and the pods, my memory plays tricks. I tested it on Saturday night and again last night. You are right, pulling back the mainbeam stalk with the lighting switch off and therefore the pods down, does not raise the pods (as I am sure it did before I had the issues) - this is therefore a useless feature in daylight unless one has fitted driving lights using the spare hardness connectors within the pod hatches (as have I). I do not know why I recalled the pods raising unless I am inadvertently recalling a friend's TR7 from many years ago. When I fit the relay bank and Panda switch, I will be interested to see what happens then
My memory is now suspect because over the weekend, I also managed to forget to bring with me my new packet of 4.8mm spade terminals needed for connecting the relay bank to the headlamp slider switch and block connector. Most annoyed.
Regarding the dim-dip ie town setting, I quite like it because in truth in town there is no real need to use anything brighter: the LED street lights are very bright. Anyhow, I used to just use sidelights in my first car way back so this is a slight improvement and will keep the function. As a motorcyclist, I am rather against (mandatory) DRLs because that removes the differentiation between the two transport modes in daylight and the human brain is getting used to dismissing the light as it is constant with negative effects on seeing m/c's approaching: cars pulling out on approaching m/cs is too prevalent.
Interesting political slant on this problem there as well! I never knew that - will be good item to bring up in radio phone-ins where the presenter wants examples of EU interference, to prove his point one way or the other - before being cut off.
Thank you very much for the kind offer but as you say, the practicalities of distance intervene. I do not blame you for fitting a new kit; makes total sense. Nevertheless, immobilisers may not be the whole answer: a friend has had his MG stolen from a residential London street, just like that.
RDS
RDS
