My fuel pump has packed in on my '79 carb fed 1500. Currently it has the (I assume) original 30 year old mechanical pump.
I guess I have 2 options. First is to replace like for like (another mechanical pump) the second is to fit an electric pump instead of the mechanical one.
If I go for the 2nd option, I know I need a low pressure (4.5-5psi???) pump but my question is;- Do I need to vary the pressure at all. i.e. on a mechanical pump, the faster the engine is turning, the more fuel is delivered, on an electric pump, I assume the pressure and flow is constant. Is this an issue or will the fuel just return to the tank when the float level is at the top?
Also, if I do fit an electric pump, do I remove the mechanical one and fit some kind of cover plate where it used to be or simply cap the output pipe?
Thanks in advance,
Mike
Thanks in advance,
Mike
