f1fan111
Hello
I have a G reg mk2 Uno 45 FIRE 999cc engine and its a Carb model and it is surfering from a few problems
1. Pulls away very slowly
2. Will Not go over 50MPH
I have some history with it as its always had these problems since it was purchased
I have checked the Vacume Unit by blowing down it and its working also this was replaced in 2001 also at the same time the Distrubtor was Removed and striped down then Cleaned out and free off internal components it says on the invoice.
Just over 1 year later the Distributor was changed for a Second hand unit.
Now i think it can not be the Distributor but what does the ECU do thats ontop of the distributor in the Carb models could this be causing the problem? also any other suggestions to what it could be
If this problem isn't fixed by end of May then i think it will be going to the Scrapyard in the sky [xx(]
Thanks for any help
Michael
Thanks for any help
Michael
