im Axle Specialists
Old 07-03-2015   #1
South Africa
Angry 95 Uno just died, no spark, new cap,ignitor, wires - stumped
Hi chaps.. just redid engine for a friend, after driving 5kms, it suddenly died and haven't managed to start it since.
Not 100% sure what model, but its a single carb (weber iirc) / non turbo with elec ignition (white cap) and no crank sensor/pickup. Maybe pacer?
Checked fuses, replaced all plug/coil wires and installed a new ignition module (silver one on the distributor).
This model doesn't have points, its electronic.. + car ran perfect before!
when u do the screw driver trick on the coil wire, it sparks when we turn car on and off, but nothing while cranking.. surely the coil should still spark occasionally?
anyway, its dead and not sure what else to try ??
is there a way to diagnose where the spark is being lost with a multimeter?? Car is def getting fuel, serviced the carb - like I said ran perfect, then literally just died and no spark since then. triple checked fuses...
I suspect the pickup is either bust or not getting power which ill check in the morning. Checked all wired in dizzy for breaks etc, found no issues. made sure coil is grounded as well as ignition module.
any ideas?
CamaroMan is offline Reply With Quote Quote
Old 08-03-2015   #2
varesecrazy has donated!
Re: 95 Uno just died, no spark, new cap,ignitor, wires - stumped
Hi,and welcome,
your car is 95% identical to the classic panda..,
that is a very Busy forum section on here,
Use SEARCH in "advanced" to find similar posts,
one of the regulars may well have come across this..
@Dragon Man may be a good 1st bet..,
Charlie
Thanks Dragon Man thanked for this post
Likes Dragon Man liked this post
Old 08-03-2015   #3
South Africa
hi tanks, i went and had a look there and searched bu nothing turned up. i have read alot of similar issues on many other sites- ill try get a replacement and see if that fixes my issue!
Old 08-03-2015   #4
I Void Warranties
Dragon Man's Avatar
Dragon Man has donated!
hey there, i fit this exact same ECU setup to my panda...
now its sparking only when the ignition is turned on and off and *not* while cranking?
if so that tells me that the coils are only getting the "pulse" when the power is cut to the ignition module. though you have replaced the ignition module, i'd swap it over again with another just to make sure.
i had this same issue. and it was that damn ignition module at fault even though it was new.
its very rare that the "point less" points ever fail
now the spark system is exactly the same as the older carbed (no ECU) version (or panda 4x4s).
the ECU picks up the engine speed from the ignition module via the ignition coil.
below i have made a wiring diagram. if you look at the coil you will see a blue and white wire coming out of the coil, but here you will also have a green wire going to the ECU (on the uno this is all built into the 4 pin plug that plugs into the coil). it is this wire that tells the ECU when to inject fuel, so no need for a crank position sensor.
this is how the ignition module is wired up:
let me know how you get on with it.
any questions, please do ask.
Thanks varesecrazy thanked for this post
Dragon Man is offline Reply With Quote Quote
Old 08-03-2015   #5
South Africa
hey - removed timing cover and found the tensioner had popped off - so the belt was not turning which resulted in no spark - figured this out because when we turned dizzy by hand as a LAST resort found good spark.
very relieved(!!!) since we tested with another and also had no spark!
tx for the comments dragon man, much appreciated!!
Old 08-03-2015   #6
Quote Originally Posted by CamaroMan View Post
so - a snapped cam-belt scenario..,
glad it's an 8 Valve FIRE engine..
Charlie
Old 08-03-2015   #7
South Africa
absa bloody lutely!! just about every other engine wd have been bent valves.. been there a few times myself!!
yes - SOOOOO relieved after i figured that out, yikesrowzee!!
Old 08-03-2015   #8
I Void Warranties
Dragon Man's Avatar
wow.. did it not sound different when you cranked it over??!
yeah even i would not have guessed that!
Old 08-03-2015   #9
South Africa
nope, possibly if i held my head to the head i MIGHT have not heard the compression, but the starter is loudish.. wd never have guessed just cant believe spent a whole day lol.. sooo glad found it..
any tips on the tensioner pulley torque? ... never had a tensioner pop out like that before - we were doing 35ks / hr - - - -
Old 08-03-2015   #10
worth double checking the bearing.. ,and the way it was fitted,
as a rule of thumb I do them pretty tight ( by hand),
it's an M8 steel thread if you want to cross reference
Charlie
Old 09-03-2015   #11
South Africa
yeah, maybe some blue loctite, although when the ignition module died - because we were doing town driving in 3rd, there was quite a big kick back from the wheels into the engine and i suspect that overloaded the tensioner (which is new - as a rule I change this and h20 pump on 'unknown' engines). Just our bd luck the module failed 5kms after we redid the motor!!
oh well - murphys law i guess!
car died while driving - wont start / no spark CamaroMan Tech Talk 4 14-03-2015 19:08
(T) mk1 sporting 16v spark plug wires problem! JaguarXJ6 Punto (Mk1) 6 22-04-2011 12:26
(T) Help: spark plug wires in 97 Sporting JaguarXJ6 Punto (Mk2/2b) 0 14-12-2010 22:52
(T) milky residue on oil cap, got me stumped chaos123007 Punto (Mk2/2b) 15 30-10-2009 09:48
(G) hid transformer/ignitor mrpink Stilo 1 06-08-2009 18:34
