I got a '87 Uno 45s.
I'm installing a Punto mk1 1.2 60hp engine in it.
The old 999cc got a carburator, i will use the Punto Loom and Punto SPI + inition.
Most punto looms are secured with an immobilizer, also for my case, so i did get a tuning chip including immobilizer remover. I bought it from a guy in Israel. Was about 30eur incl shipping.
I got a P75 (punto 1.2 8v 75hp) engine and loom as well but so far no immobilizer found.
http://myworld.benl.ebay.be/chip2race?ssPageName=ADME:X:RTQ:BE:1181
Stock
plastic removed
installed
Did a test as well.
Ordered a waterpump cambelt(15x108) tensioner and thermostat (65eur as set on ebay)
Yesterday disconnected and removed the engine and gearbox.
Note i have the old uno mk1 gearbox with the 2controls under the car, uno mk2 have the 3controls through the firewall, i think this is the same type as punto mk1. Punto mk2 is again a newer type.
I did read the 1242 block is a bit fatter and you should grind off a bit from the block.
the middle bolt doesnt fit! (P60 engine, P60 starter, Uno-plate) > hope this works and match
(i've seen the flywheels are pretty much the same, the clutches are diffrent size, P60 is bigger, diffrence for the flywheel is only the surface where the clutchplate matches. I think the clutch will work in the older type gearbox)
pattern is a bit diffrent
uno gearbox, P60 starter
I hope i can fit the P60starter with just 2bolts without grinding.
Stock
plastic removed
installed
Did a test as well.
