Old 14-01-2013   #1
Trader Rating: 1
Punto GT3 Engine into Mk1 Uno 45s
Currently have a 45s running 1242 8v FIRE engine with larger carb,
My friend has recently bought a written of Punto GT3 complete running car.
As far as i'm aware i will have mounting holes in the body that will allow engine to be bolted in with Uno Lampredi mounts.
Will it be possible to use the Punto GT gearbox, possibly with a swap of the selector mech?
Is there any way of using my current driveshafts or even the Punto GT ones or will i have to find Lampredi Uno or UT driveshafts & hubs etc?
Exhaust and wiring etc is not a problem can easily be fabricated.
Many Thanks
Ben
benwyl is offline Reply With Quote Quote
Old 15-01-2013   #2
All go, no show
lewey's Avatar
lewey has donated!
Re: Punto GT3 Engine into Mk1 Uno 45s
Hi Ben,
The engine and box will mount with Uno Turbo style mounts to any shell.
or an easy gear change conversion you will want a gearstick, rods and selector lever (top of gearbox) from a UT. You probably won't have holes in your bulkhead for the rods to go through though, so you might have to drill them.
Driveshafts are too long for the UT and will either have to be shortened or UT driveshafts (including shaft behind engine and half shafts in gearbox) found. Either way, they will have to go into UT (also diesel) hubs, as these have different size splines.
Otherwise should be fine.
lewey is offline Reply With Quote Quote
Old 15-01-2013   #3
Trader Rating: 1
Thanks for the help Lewey, you mention diesel hubs. In my yard behind our flat is the landlords old Citivan think its a 1.7 diesel that has sat there for years, is there anything useable on it? Will i be able to use diesel driveshafts and hubs? Will diesel mounts be the same?
Ta
Old 16-01-2013   #4
Trader Rating: 1
my uno turbo uses a gt3 centre and offside driveshaft they do fit
oldskoolmk1unoturbo is offline Reply With Quote Quote
Old 16-01-2013   #5
Trader Rating: 1
Quote Originally Posted by oldskoolmk1unoturbo View Post
Ah interesting to know, is the nearside one too long then? Guessing you're already running Uno Turbo hubs etc already unlike me?
Old 17-01-2013   #6
All go, no show
lewey's Avatar
lewey has donated!
Quote Originally Posted by benwyl View Post
Ta
Certainly possible that the citivan hubs are good. Basically if it has the C510 gearbox, it has the right hubs and I would expect it to have a variation of the gearbox due to the diesel lump. You could also potentially use it's driveshafts and halfshafts. On the diesel and later 1372 petrol models they used shafts that go straight into the gearbox, without the use of half shafts like the UT. Not as strong or balanced, but might do you.
Can you clarify for Ben and I which shafts can fit? I know they have the same flanges and splines, etc, but my memory was that all the parts are longer than the UT. The half shafts are only a little bit longer, so can be squeezed in? Perhaps you have lowered suspension that is helping in this regard?
Old 18-01-2013   #7
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Louie Bee has donated!
Rollin X Pinball Champion, Bubble Bobble Champion
Mozambique
Ben, if yours is Late E reg or newer shell you should have the hole in the bulk head. Mine did when I converted to top change.
Lewey didn't you us a brava gear shift setup on an UT box? Would save ben trying to get the steering rack cover plate with the pivot point, and not have to make up rose jointed rods, still to be left with slop.
Louie Bee is offline Reply With Quote Quote
Old 23-06-2014   #8
Trader Rating: 1
Quote Originally Posted by lewey View Post
I am using a punto gt centre and drivers side driveshaft, when I fitted them they seemed to be almost identical to the uno turbo driveshafts
(T) MK1 Uno 45s Fire 1ltr Refusing to start! - coil squeeling!? wtf! happypaul Uno 6 09-11-2009 12:36
1989 mk1 Uno 45S Chas Uno Auction Watch 1 21-06-2008 09:12
mk1 Uno 45S - 24K miles!!!! Chas Uno Auction Watch 0 12-11-2007 01:05
red mk1 uno 45s - watford Jai Spotted / Was It You? 13 19-03-2006 20:25
