Thread Tools
Old 21-08-2011   #1
uno turbo gearbox
Can a mk1 uno turbo gearbox be changed for a mk2?
ben taylor is offline Reply With Quote Quote
Old 21-08-2011   #2
cha40 has donated!
Re: uno turbo gearbox
If you mean bottom to top change then yes, but you need the gear linkage and bigger clutch.
cha40 is offline Reply With Quote Quote
Old 23-08-2011   #3
Thank you, I have a mk1 uno turbo and the gearbox has blown up, I was just seeing what options I had, as Mk1 gearboxes are rare as rocking horse . . . .
Old 24-08-2011   #4
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Louie Bee has donated!
Rollin X Pinball Champion, Bubble Bobble Champion
Mozambique
Have a look which gearbox your MK1 has.. if there is an under car gear linkage you have the older type known as the bottom shift, which requires a fair few parts to convert to MK2 (i've done the conversion but not driven yet)
If the selector mechanism travels through the car and through the bulkhead and enters the top of the box it's the topshift (oddly enough). If you have this type, then it's much easier to convert to MK2. the MK2 box usually uses hydraulic clutch but can be converted to cable if you swap the clutch arm over as the casting retains the cable bits.
I think it was e reg and before which have the older box, and I guess you have this box as they are prone to failure by all accounts.
Louie Bee is offline Reply With Quote Quote
Old 24-08-2011   #5
Germany
The top shifted gear version used the so called TIPO gearbox.
No hydraulics on a European UNO I know of.
The old gearbox is known for not being a reliable gearbox.
Also a good reason to swap to the newer TIPO gearbox.
johorridoh is offline Reply With Quote Quote
Old 24-08-2011   #6
All go, no show
lewey's Avatar
lewey has donated!
RHD Unos with the later C510 "Turbo" box also used on diesels did have hydraulic clutches. Like mine does.
lewey is offline Reply With Quote Quote
Old 24-08-2011   #7
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
I'd bet the hydraulic clutch on the MK2 would only be for Right hand drive... just like the 1.0 n 1.1ie Uno and Novo Panda .
Donít buy a box off a Tippo. as itís ratios are not right and has different drive shaft matings IIR.
Thread Tools
(T) Punto GT Gearbox and Uno Turbo MK2 Gearbox samsonite Punto (Mk1) 0 22-11-2009 14:15
(T) Uno Turbo Gearbox ceedy X1/9 5 13-09-2006 21:34
