Great thread - now I am on the look out for either a 1.6 or a 1242 Punto. Not for racing, just a fun project and making my uno more fun to drive.
Chas, you seem to have looked into this more than me.
Am I right in saying that doing the 1242 in an uno (from 999cc) is pretty much as straight forward as doing it in a cinq sporting?
Use everything the same except for the actual block itself (so use the 999cc flywheel and crank?)
Its still something I would love to have a play with. Would really love to do a 16v conversion but its still something ide feel uncomfortable trying even in a cinq/sei! Its just not documented as well as the likes of the 1242 8v conversion.
Yes! Remove 999cc engine. Install Punto 60 1242 in its place. Bolt up Uno gearbox, connect the Uno ignition and fuel system and it's done. Jason 45 can elaborate a bit more as he's done it. I think you might even be able to use the Punto down pipe which removes the need to make a spacer for the exhaust.
wouldnt it be better having a 1.4 8v N/A engine? some unos did come with them, seems pointless to me doing a conversion when theres no need
For what its worth I am about to have a "new" race prepared 1580cc engine from a Tipo built up and fitted to my race Uno to replace the 1372 unit that I destroyed earlier this year. The new engine should mate to an Uno Turbo gear box (Top Change Tipo type) and driveshafts.
The race engine prep won't be complete until Feb and then theres the installation to do so we might discover problems then, but it seems OK 'in theory!
