If it is the fuse the both hazard and indicators would not go at the same time. The hazard warning light has a fuse in the box under the dash. The indicators are run from the services fuse. If i remember correctly they go to the hazard warning switch from the fuse. so if the switch is no good neither hazard nor indicators will work. if the flasher unit attached to the stearing column is bad then they wont work either
