Technical  Tpms
Technical  Tpms
Rick80SX
Stoke-on-Trent
Hi guys, I have a 2017 Tipo lounge tjet that I purchase recently and have a little query about the tpms. It’s not displaying any numbers on the dash on the tpms display and I was told that this version of the car only has the warning light which goes off the rotation of the wheel? I just wanted to check if this is the case as I find it a bit strange that they’d put the display on the dash and not include the function to actually see the pressure?
Cheers.
Thanks guys, so there’s no point to the display? Or will it tell me which Tyre needs attention? Seems completely pointless!
It does pick up a tyre with reduced pressure, its best to carry a pressure gauge to check which one is going down.
As said it just states check tyre pressures... you have to check all four with a gauge. And I’m also convinced it goes off after a set time or mileage if you don’t reset it once in a while. I’ve had mine go off twice in 12 months and all tyres were fine...
