im Axle Specialists
Old 11-02-2019   #1
Start stop issue
Hi, I’ve got a tipo s design and I’ve recently noticed an issue with start stop, and I don’t know if it’s normal or not. Basically when the car goes into start stop sometimes it disconnects while the engine switches off and then the car stays in idol mode. This means I have to turn the car off then turn on again to start moving again as the you cannot wake it from sleep mode by pressing the clutch. Is this normal? I’ve reverted to keeping start stop off until I resolve the issue.
Thanks for your help in advance.
fabioconte is offline Reply With Quote Quote
Old 11-02-2019   #2
JTD_Liam has donated!
Re: Start stop issue
I leave start-stop permanently off in my Tipo as I think Fiat make a dreadful job of it, but in my Parents Fiat 500 it used to do exactly the same as you describe. My guess is the dealer will charge the battery, which will solve the problem temporarily. Then they'll change the battery for a new one, which will also solve it temorarily. Then it'll go back to doing exactly the same as it does now. The amount of owners of Fiat group cars with start stop, reporting that it doesn't work 100% is staggering, hence why I just switch mine off. Plus we don't know what damage it's doing to the rest of the mechanical bits with the engine stopping and starting loads more than it would ordinarily, and Fiat won't care because chances are that damage will only materialise once the car's out of warranty and it won't cost them, it'll cost you or me!
2003-2005 - 1996 Punto 75SX 5 Door -- 2004-2008 - 2000 Punto JTD HLX 5 Door -- 2008-2014 - 2004 Stilo JTD Dynamic 3 Door --
2014-2017 - 2013 Alfa MiTo -- 2017-2018 - 2016 Alfa Giulietta
2018-Current - '68' Tipo T-JET S-Design - Street Grey
JTD_Liam is offline Reply With Quote Quote
Old 12-02-2019   #3
Thanks a lot for your comment. The only thing I found strange is that when the start stop fails and the car was already in start stop mode (basically fails mid start stop) that the car doesn’t restart again so you can at least drive off. In my case the car doesn’t restart so you have to turn the engine off and on again just so you can drive away. I had an Audi A3 before this and it also failed sometimes
But the engine turned on when it did so I could keep moving. This is why I was wondering if this may be a fault. What do you think?
Old 12-02-2019   #4
Is there a way of turning off start stop permanently? On my 500X if the button was pressed it was off all the time. With my Punto you have to press button every time you get in the car.
twobigdogs is offline Reply With Quote Quote
Old 12-02-2019   #5
Quote Originally Posted by fabioconte View Post
Yeah this is what the Parents Fiat 500 did. Sometimes it'd fire the engine first, but sometimes it'd stop, then beep and say 'Start Stop Unavailabile' and that was that. You'd have to turn the ignition off and back on to get it going again. It'll probably only be solved (for a while) with a new battery or by switching off the start stop. It's not very good.
Old 12-02-2019   #6
Quote Originally Posted by twobigdogs View Post
On my Tipo there's a button to the right of the hazard warning lights button with an A surrounded by an arrow. Press that and an orange light should come on in the rev counter area, which stays on permanently. That's the start stop disabled. On my 2018 model (Pre WLTP emissions testing) once I switched it off, it's stayed off, unlike some Italian cars we've had that you've had to switch it off each time you start up the car.
Old 12-02-2019   #7
Quote Originally Posted by JTD_Liam View Post
My 2019 tipo lounge you have to press the button every time you start the car to switch it off. When you get back in the car it doesn’t remember the off position and needs to be pressed again.My old 500x once it was switched off it stayed off.
Old 12-02-2019   #8
Oh that's annoying. Must be linked to WLTP or perhaps a model year change, as you have the same 1.4 T-Jet 120 engine as I do I think? I don't think the 1.4 16v 95 petrol has start stop but it'd be interesting to see other people's findings. Yours is one of the very latest models as it has the 7" UConnect, which Lounge spec has only just gained.
Likes twobigdogs liked this post
Old 12-02-2019   #9
I wanted an s design because of the 7” screen but was told all the new lounge spec had them as standard. They had one in stock and got it in two weeks.....well pleased. I still like the s design wheels but lounge worked out a fair bit cheaper with nearly same spec.Impressed with Apple CarPlay and the new 7” screen.
Old 12-02-2019   #10
I'm glad I got the S-design as I also like the wheels, plus the Street Grey paint is only available on that trim level. However
I would've been happy with a dark grey Lounge if it'd had the bigger touchscreen - the 5" unit that the Lounge had last year was just not good enough in terms of size, resolution or functionality after coming from an Alfa with the (albeit compromised),6.5" UConnect Live unit. If I chose now I'd have the Lounge with the 1.6 Multijet engine as I do find the petrol mpg hard to deal with after years of Fiat/Alfa diesels.
Old 12-02-2019   #11
Mine came in metallic grey so with the chrome accents looks very upmarket for a Fiat. I’ve had many friends and family comment on the quality looks......
Likes JTD_Liam liked this post
Old 12-02-2019   #12
Thanks all. I think I’ll just keep it my start stop off then ain’t worth the agro 🥴
Likes twobigdogs, JTD_Liam liked this post
Old 13-02-2019   #13
They do look good in the dark grey in particular. I like how they've managed to create a definitive step-up in terms of looks as you progress up the Tipo range - the Easy is like the Panda Pop, clean simple lines. Then Easy Plus adds the alloys and fog lights, while Lounge adds larger powder coated alloys and chrome bits.
Thanks all. I think I’ll just keep it my start stop off then ain’t worth the agro ��
That's probably the best option, because unless the Tipo is different to other Fiat's i've experienced, your Tipo's behaviour seems pretty typical for Fiat's start-stop system. It may work effectively after a long journey, but after a while it'll go back to what you've experienced until you do another long journey. Switching start stop off was one of the first things I did when I collected my Tipo in September & it's not been altered since!
Old 15-02-2019   #14
Yep, my stop start rarely works ... don't really know why although I understand the system measures all manner of parameters, battery temperature, current etc etc. Curiously I do notice that after disconnecting and reconnecting the battery sensor, and the battery, it starts to work again...for a while and similarly might work once, twice after a motorway trip. It once restarted without touching the clutch. I've also heard of people having fun with stop start on automatic cars! So myself, apart from being a little irritated because something's not doing what it's meant to, I just put it out of my mind now....
AMMJ is offline Reply With Quote Quote
Old 17-02-2019   #15
Update - Took it for a couple of hundred mile night away drive and yeah, stop start worked proficiently after the run. So maybe the battery just doesn't get the charge required in my normal driving pattern.
(T) 2014 Fiat 500 Stop/Start issue filmlover25 500 12 12-10-2020 02:22
(T) Panda Twin Air Start & Stop issue. The Pretender Panda (2012+) 54 30-08-2020 18:49
(T) Stop/Start battery issue craigdlewis 500 8 25-01-2016 21:17
(T) 2015 500 Start/stop issue Ex Volvo Victim 500 7 18-05-2015 02:14
500 TwinAir Duologic stop start issue cabriogay Lets Talk FIAT 0 05-04-2015 12:24
