General Ze Cranky-Case Emission Control Query!
Originally posted by ottiian
I've just put one on today and deciding whether to keep it or not.
The car definately has a bit more torque, but the noise is deafening!
Are the kits really supposed to be so loud? It sounds like a 10" sub on full power, at around 4000rpm.
I can feel ppl looking!
what one did you use?? how much?? where from?? and any mods needed??
soz about all the questions i just like to know
It was only a 'cheapie' one, £30, from a local auto spares shop. Plus £10 for a breather for the crankcase ciculation (the 'mini' filter)
It was very easy to fit, no modification whatsoever, took ten mins.
The filter had a 60mm neck, but doesn't bolt on, so what I did was:
1) Took off all the old air box.
2) Took off the pipe that brings air in from the duct in the bumper (it is pre-bent into the correct shape I needed! and it was 50mm - perfect)
3)using a jubilee, and after taking off the rubber and metal gaskets from the top of the carb, i placed the correct end of the pipe (u will know because of the way it is bent to allow filter placement in the engine bay) at fastened it - perfect fit, the diam. of the carb top is 50mm.
4)Using a piece of soild old 50mm tube I had around, of very short length, say 50mm, attach one end to the pipe and the other attach to the filter using it's prefitted jubilee clip.
5) Now, you just have to take off the rear cover to the left headlight
6) The filter positions itself perfectly snugly in the space to the bottom left of the engine compartment, behind the headlight. It even fitted in my car with the ecu in the way which is fixed there
7)The inlet pipe is already there from the bumper, upgrade it a bit - perhaps a bit of pipe to direct airflow, etc.
8) Fit the breather filter to the cranky pipe and I just used some small malleable metal wire to secure the filters - all you need.
9) Prepare to be deafened.
hope this helps
Perhaps you have a resonance in some of the 50mm pipe sections at 4K.
Maybe (4000/60) * 4 (number of cylinders) is about 267 Hz
quarter wave resonator might be 1100/(267*4) which is about 1 foot,
or 30 cm in Metric.
Try it without the inlet pipe, and see if it booms as much.
I'm pondering this little dilemma myself. I definately want to replace the existing air filter. The choice of induction kit, 'bolt on' or replacement filter is a tough one. At the moment I'm leaning towards replacement filter, in order to avoid the carb iceing, plus I really like the look of the fiat airbox (especially cause I've painted it bright orange). If only I could figure a way of hooking both the induction kit and the panel filter. Not in series, but as a switchable option. I have been toying with the idea of putting a pipe from the induction kit into the post filter side of the airbox, with some kind of gate in it. I would also have to split the air intake pipe with a similar gate. Any ideas/thoughts?
This might just be a bit OTT but this problem has got my attention at the mo.
