rossino626
- Joined
- Mar 19, 2009
- Messages
- 4
- Points
- 1
The engine management light in my Punto has been on solidly, not flashing, for about a month. It has problems starting sometimes and cuts out when stationary. Other times it can run perfect. It is not the first time I have this problem. It happened before and I took to a Fiat garage they ran some tests and found a problem with the CAT and inlet manifold, so manifold was replaced and for a few days it ran fine, then it cut out and the light appeared again. I have also had the battery changed.
Has anyone encountered the same problem? Can anyone help!?!?
