AiR
http://www.indiacar.com/infobank/clutch.htm
the bit i found within it :
Racing drivers can change gear without a clutch and you can too in an emergency to drive a vehicle without using the clutch. The starter motor is powerful enough to start a vehicle in first gear on the flat or even up a slight slope, although it is not recommended as common practice! (Also useful if stuck with a dead engine on a railway crossing when the express is due.) Running up to say 3000rpm in first gear, back off the throttle to take all load off the transmission and put the gearbox into neutral. Get the engine to about 2000rpm (assuming adjacent gears are in the ratio 3:2) and, with care, you should be able to engage 2nd gear with no clutch. Other gear changes are managed similarly. The engine must be turned off and the process repeated if you have to come to a halt. There will probably be a good deal of gears "grating" but with care, "feel" and lots of patience this can get you back to civilisation.
Seicento : Yellow : 1108
Cool As Penguin ****
